i need help
  • Thread starter Thread starter evilstang98
  • Start date Start date Jun 24, 2010
E
evilstang98
van nuys ca
Jun 24, 2010
  • Jun 24, 2010
whats up my people , am new here and i need help . here it goes
i have a 98 gt with procharger and intercooler with 42 pound injectors ,
90mm lighting mass air, external pump . and a diablo chip with a custom tune full bassani exhaust except headers . no cats .
ok i just had it tuned and it made 274hp and 301 ft torque the with 7psi.....
the tuner guy told me that my car made 174hp. with out the blower . wtf the car stock should have 225hp .i dont get it . i feel like a went backwards on this project . i dont get what i did wrong . can anybody tell me what i did wrong ? the car has 53k miles on it ....
D
Deleted member 38176
Jun 24, 2010
  • Jun 24, 2010
Do you have any PI parts (intake, heads, cams)? Even a non-PI GT should put at least 300+rwhp with a blower. Obviousy there is something very wrong with your car. Hopefully someone a bit more knowledge in the area will chime in.
BurningRubber
1,865
24
58
Jun 24, 2010
  • Jun 24, 2010
Well, the 174hp he is talking about is likely at the wheels. Once you figure in drivetrain loss from the engine to rear end, you do lose a certain percentage of power the engine is making before it hits the ground.
Is the car a 5 speed or auto? If it's an auto, that isn't too, too far off (a little low), but if it's a 5 speed I'd expect it to be in the mid 180 to 190 range.
7psi isn't a whole lot. You basically gained 100rwhp over stock. That's about right, seeing as a 99-04 GT will dyno 225-235rwhp through a 5 speed, and with a run of the mill Vortech S-trim kit between 7-9psi the car will make around 340-360rwhp depending on other mods.
The biggest thing you could do is a full PI swap (99-04 heads, cams, intake). That's pretty involved, but on a smaller scale you can just run the PI cams and intake on your car and see pretty good gains. You'd still have to re-tune though.
If you have a dyno graph, what does your air/fuel ratio look like? Did he say how much timing he's using? I would expect it to be a little higher, but there are still a few variables to figure out. You can definitely get a non-PI to make 300rwhp or a little better with a safe amount of boost. I'm sure if you turn it up to 9psi you would be there, or very close.
M
Midnight2V
224
Oklahoma
Jun 24, 2010
  • Jun 24, 2010
Stock NPI motors peak at about 5100 RPM and then fall off big time. More so than what your procharger can overcome. Your motor may peak at 7PSI but you are probably well past the point where the engine is productive despite your boost. You are probably at only 5 psi at your power peak. You are intercooled, your compression is only 9.2:1, and you have sufficient fuel, I say pulley down for 11-12 PSI and enjoy. But that's just me.
sneaky98gt
2,387
144
114
NC State University
Jun 24, 2010
  • Jun 24, 2010
Auto or 5-speed?
MustangDyno or Dynojet?
And can you post a dyno sheet?
If your car is an auto, and have no more mods than 7 psi of boost and a mid-pipe back exhaust (which is all you have said you have), then your numbers really aren't all that low, especially if it was dynoed on a MustangDyno (which reads a good bit lower than a Dynojet). The NPI intake and NPI cams are EXTREMELY restrictive, especially with a blower; I can't stress this enough. PI cams and intake are said to gain 30 hp on a stock NPI car, so I'm sure you'd gain 30+ hp with those two mods. That would put you at a solid 300 rwhp; I'm making 325 on a Dynojet with a couple more intake mods, so if you are on a MustangDyno, our numbers would then [hypothetically] be about the same.
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
S302 Saleen supercharger help
  • sschoup
  • Nov 19, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Nov 19, 2025
sschoup
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
A
Please!? I need some help with my 1964.5 alternator conversion
  • Alabear94
  • Dec 6, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
GOvert
G
I need help with an 06
  • boviske underwood
  • Oct 30, 2025
  • Services - Tuning, Welding, Mechanic, Body Work...
Services - Tuning, Welding, Mechanic, Body Work... Oct 30, 2025
boviske underwood
