I really ****ed something up this time
  • Thread starter Thread starter Synned
  • Start date Start date Aug 6, 2005
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Aug 6, 2005
  • Aug 6, 2005
So i was installing an alarm/remote starter today and I finally got the car to be started remotely. Then I shut it off then it attempts to start again but makes a horrible sound. Then there was no power to anything, so we checked the fuses and they are all good including the ones inside. Then we unplugged and replugged in the battery and we get power. The problem is I cannot start the car. I go to start it and it does on click like crank noise and shuts off all power. Maybe its a short?
2badazzstangs
72
Jersey
Aug 6, 2005
  • Aug 6, 2005
check the starter wire, im assuming you had to cut this for the start kill portion of the alarm.
Synned
Mar 31, 2005
991
Philly
Aug 6, 2005
  • Aug 6, 2005
Yeah, the starter wire is back together. I removed the remote start portion of the car. Now when I attempt to start the car it does 1/2 crank i dont even know if its a crank and dies. Then cuts power to everything. Then we unplug and replug battery and we get power back. Maybe the battery got drained somehow?
2badazzstangs
72
Jersey
Aug 6, 2005
  • Aug 6, 2005
the battery could have drained during the install, i assume it took a few hours and your domelight may have been on. Check your battery first and if thats not it, recheck your wire connections. Did you use a volt meter to check the column wires
BlownStangGT
REPEAT
3,860
Lancaster, PA
Aug 6, 2005
  • Aug 6, 2005
that horrible noise mighta been the starter... have you checked to see if you didnt kill ur starter?
Synned
Mar 31, 2005
991
Philly
Aug 6, 2005
  • Aug 6, 2005
Guys, stupid me, the battery - wasn't tight, I thought since it was giving power it wasn't that but yup, tightened it and boom.
mustangjoe87
364
Harrison Twp., Michigan
Aug 6, 2005
  • Aug 6, 2005
that'll do it happens to everyopne now and then
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Aug 6, 2005
  • Aug 6, 2005
lol yep its happened to me
2badazzstangs
72
Jersey
Aug 6, 2005
  • Aug 6, 2005
could have been a lot worse, im glad thats all it was
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
