The middle main headlamp is working on both the driver and passenger side and that is all. The blinkers will work when turned on and the reverse and brake lights work when pressed but the lights do not come on when you push on the headlamp switch.
What to replace/check???
I have checked all fuses which revealed nothing.
I have replaced the ignition Switch.
*What do you look for or check when checking grounds?
What next?
What next?
