I think it's the timing
  • Thread starter Thread starter 66overhaul
  • Start date Start date May 8, 2007
66overhaul
22
  • May 8, 2007
Good afternoon:
I have a 66 coupe with a standard 289. I recently put in a new starter, battery, various wires, Edelbrock performa RPM Intake manifold, Holley 4B carb, radiator, hoses, distributor components, and transmission cooling lines. Now it won't start!
I figured it was the timing, and got it to just about start up, but it won't do it. I am wondering if anyone had any thoughts. I am considering an electronic ignition, because i wonder if the stock distributor is just too weak.
Any ideas?
R
RUSTYNUT
128
PDX
May 8, 2007
  • May 8, 2007
My first guesse is the timing 180 off. [ done that a few times]. Plug wires not in correct place, point gap and dwell not set right. Electronic ignition will save you loads of time on tune ups. You don't need it to get your car to start.
Decurion
353
Livonia, MI
May 8, 2007
  • May 8, 2007
The Pertronix ignition is stupid simple to set up and at $75, not expensive. Will give a hotter spark too, so more power and better mileage. But... its still gotta start...
krash kendall
1,258
Aldergrove, B.C. Canada
May 8, 2007
  • May 8, 2007
Pull the spark plug leads off, yank the distributor out, then start from the beginning. You need fuel, air and spark - at the right time.
Did you remove the distributor at some point and do you know the procedure for re-installing it?
Max Power
1,774
St Paul
May 8, 2007
  • May 8, 2007
What does "distributor components" mean? Distributors don't get weak. They don't create, they distribute.
Did you pull the dizzy or no?
HistoricMustang
2,359
Confederate States of America
May 8, 2007
  • May 8, 2007
Lets not forget a good engine ground.
Use two..............one off the back of the intake and one off the front of the engine.
HistoricMustang
mrfomoco
108
The Woodlands, Texas
May 8, 2007
  • May 8, 2007
Where would you attatch the one on the back of the intake to?
Max Power
1,774
St Paul
May 8, 2007
  • May 8, 2007
Firewall.
  • dan50
  • Jul 18, 2026
dan50
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
J
Hello all, I have returned from a hiatus... Update and Questions
  • JackH
  • Aug 13, 2025
1974 - 1978 Mustang II Talk & Tech Aug 15, 2025
JackH
J
F
carb vs cam help needed
  • forango
  • May 2, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2025
forango
F
