I wouldnt do this to my g/f
Black 93 Fox said:
Did you get the DFI done?
Well, drained the tank, put in a 190 pump, swapped out all the sensors, hooked up the fan relay, installed an air temp sensor, made an intake runner temp sensor, and yanked all the EEC4 junk out. Tommorow I will start laying in the pcm and harness and hope that the electrical gods are with me:) Something tells me I am taking this way too far for a 4 banger....but at least its a Ford
Awsome you gona dyno it see what it makes? Im gona come by the shop tommorow some time. Have Jeff look at my clutch since I have it out. See ya tommorow. Hope to hear it run!
Andy
I will dyno it (just for tuning, dont care about the numbers) after California...need to break it in good. You know what break in is, right
...speaking of your clutch:D, me and jeff should both be around tommorow, so bring her by. I doubt it will be running tommorow, but you never know!
I broke the damn thing in. I dont know what went wrong with it all I know is that it is a POS. I did look at it kinda. The area around the springs was blue and kinda red looks like it got real hot. Dont know if that is normal or not.
See ya tommorow.
I know you say you broke it in right, but we will see tommorow:) Which clutch are you going to try next? I have the old one out of my Escort if you need it:p
Hehe. By the way....real racecars have Automatics:)
If you want a car to run this friday, you can use mine:)
Real racers may use auto's but it takes some skills to race a stick. I might take you up on the race firday. See what racing a auto is like. Not gona be able to race mine for quite awile and im already getting the speed bug. Probaly gona try a high stage spec.
