Not sure if my IAB is working right or not. Question: what, if anything, happens when you disconnect the IAB while the car is running ? I disconnect mine and nothing happens...........is that normal.
Its prolly bad then. take it off and throughly clean it with carb cleaner and reset the ECU by pulling the battery leads off the batt for a few minutes. and its the IAC not the IAB you are prolly reffering to (Idle Air Control
