  • SN95 4.6L Mustang Tech
IAC?? How to tell when bad?
  • Thread starter Thread starter 98blackstallion
  • Start date Start date Jul 25, 2007
98blackstallion
602
mtn home arkansas
Jul 25, 2007
  • Jul 25, 2007
Ok before my IAC valve had a VERY strong suckion to it but today I checked it and it hardly has it suckion at all. So is it bad? I know this is a stupid question but Im curious! Oh yeah car wont idle either.
RandyStinchcomb
1,159
Randallstown, Md
Jul 25, 2007
  • Jul 25, 2007
do you have more than 75k on the car? how often has the PCV valve been changed?
chances are you'll need a new one
98blackstallion
602
mtn home arkansas
Jul 25, 2007
  • Jul 25, 2007
the IAC has around 123,000 miles on it but Ive kept up with the PCV valve but i think my IAC has kicked the bucket.
BennyBlown2v
1,233
Carmel, INdiana
Jul 25, 2007
  • Jul 25, 2007
Are you getting a check engine light? If so, what code?
98blackstallion
602
mtn home arkansas
Jul 25, 2007
  • Jul 25, 2007
nope no check engine lights
kylebgt
  • Jul 25, 2007
Are your rpms stumbling? especially when cruising to a stop? if so you will need a new IAC for sure. Cleaning it will just make the problem worse, just pick up a new one.
kylebgt
  • Jul 25, 2007
Seafoam wouldn't be a bad idea either.
BLKsteeda
236
Anywhere
Jul 27, 2007
  • Jul 27, 2007
What issues would a bad PCV valve cause? I'm at 66k miles and still on my stock one
RandyStinchcomb
1,159
Randallstown, Md
Jul 27, 2007
  • Jul 27, 2007
uncontrolled blow-by which gunks-up the intake manifold, IAC, and other related parts.
the PCV valve should be changed at 30k under Normal intervials
BLKsteeda
236
Anywhere
Jul 27, 2007
#10
  • Jul 27, 2007
  • #10
well I'm about 30k miles over...does it cause idle issues, stalling?
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
E
Alternative IACs?
  • Ethereal_Zer0
  • May 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 7, 2025
CAMTWO1070
