  • SN95 4.6L Mustang Tech
IAC idle problem....need help FAST!!!!!
  • Thread starter Thread starter bullitt125
  • Start date Start date Oct 16, 2004
bullitt125
  • Oct 16, 2004
Question/problem:
When starting up my Bullitt cold, the car wants to stall. I cleaned the IAC out and reinstalled it. When starting the car again, it stalls unless the gas is depressed a bit to keep the car idleing. Becoming frustrated, I began to back the car in the garage and the car was running fine. Does the IAC only "work" when the car is cold? Or does it work all the time? Has anyone had any problems with this and if so, how did you fix it? The car has 37k miles and this should not be happening so soon. Any help is appreciated. Thanks
-Mike
SilVert99GT
75
  • Oct 17, 2004
I'm on my second '99 GT which had this problem. The Ford shop manual indicates that the IAC SHOULD NOT be cleaned as it is coated with a special sludge. As you discovered, cleaning it doesn't work or only works temporarily. You have to replace the IAC. It may be cheaper from an auto parts place (~$50) than from the dealer(~$80).
Btw, after searching for an answer to this problem on this and other mustang boards when I first experienced it I learned that this is a very common problem with the late-model GT's. This IAC problem really ought to have been properly addressed by Ford. I filed an official complaint with the NHTSA but never heard anything back from them.
AdamantiumKnot
894
nj
Oct 17, 2004
  • Oct 17, 2004
there have been tons of threads about this. yeah just replace the iac. i had that prob on my 98 gt and once the car would warm up it'd be okay, but def had to keep my foot on the gas for the first couple minutes.
9
99YellowGT
12
KY
Oct 17, 2004
  • Oct 17, 2004
Sometimes you can remove the IAC and clean it but it is just a temporary fix. Had to bite the bullet and buy another one from FORD. Call around though. 4 dealerships only 30 miles apart had price differences of $35.
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
  • Gulftown980x
  • Jul 29, 2026
squeak93
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
M
3.8 start problems. New edge 2003
  • Mayk.i.
  • Oct 2, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 3, 2025
manicmechanic007
