Hi, I have 2 IAC motors and both seem to give me the IAC motor error code? So is there any way I can check to see if these are working off the car? You know how you can take the IAC motor apart. There are two pieces, one has the wires connector hooked up the other part is the part that actually bolts on. So if you have the part with the wire connector only, can you check that part somehow off the car??
Thanks!!
It just seems odd that both would be bad, is there any other reason I could be getting the code that points at the IAC?
Thanks!!
