IAC???????
  • Thread starter Thread starter sweet93hatch
  • Start date Start date May 9, 2004
sweet93hatch
57
  • May 9, 2004
As most of you know, I drive around with my IAC unplugged because of surging idle when plugged in. Well, I finally got around to putting a new one in from advance auto and no dice. As soon as I plugged it in, it idled right back up to 3000 rpms. Its crazy and its making me CRAZY. Any help appreciated as always. Happy mothers day to all those out there who have little future stang bangers.
HO93LX302
715
Naugatuck,CT
May 9, 2004
  • May 9, 2004
Do you know what your tps voltage is by any chance?? should be .9-.99 volts
sweet93hatch
57
  • May 9, 2004
How do you check that. I have a voltmeter, but where do you probe?
HyPer-50
377
Woodstock, GA
May 9, 2004
  • May 9, 2004
If you unplug the IAC and the engine remains running, i believe that means you have a vacuum leak... Might wanna look into that..
HO93LX302
715
Naugatuck,CT
May 9, 2004
  • May 9, 2004
You could have a vac leak but also you can unplug the iac and the car will run if the throttle plate was open a bit.. just that it will be at a slightly higher rpm at idle
HISSIN50
34
129
May 9, 2004
  • May 9, 2004
and with no IAC, there will be no accomodations for load (a/c, etc).
after hookin it back up, you might want to disconnect the battery, turn on the headlights, and then re-hook and run it. it might need to relearn some stuff (some computers like this, and some incorrigible ones dont care). worth a try, i think.
good luck.
sweet93hatch
57
  • May 9, 2004
I'm at my wits end with this deal. I've tried everything and nothing works. Am I losing out by leaving my IAC unplugged because I can't find anything wrong.
dvs bullet
326
Ontario, Canada
May 9, 2004
  • May 9, 2004
Do you have a vacuum gage? What is your vacuum pressure?
BlackVert
5,589
9
98
Bethesda, MD
May 9, 2004
  • May 9, 2004
maybe you have a short in the iac connector?
sweet93hatch
57
#10
  • May 9, 2004
  • #10
Does it hurt to run without it?
dvs bullet
326
Ontario, Canada
May 9, 2004
#11
  • May 9, 2004
  • #11
I don't know that it would hurt to run without, but you are definatly not benifiting from it being off. Check your vacuum and see what it is at, I had similar to the same prob, it's amazing how much a small vacuum leak can screw things up. Run your codes, mine gave a thermactor code all the time, the line leading to it were all broken up but patched.
sweet93hatch
57
#12
  • May 9, 2004
  • #12
I'll run codes tomorrow and see I come up with.
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
