  • SN95 4.6L Mustang Tech
iac
  • Thread starter Thread starter 00GTpony
  • Start date Start date Apr 30, 2007
00GTpony
162
  • Apr 30, 2007
OK so i cleaned my iac out last week, and while putting it back on i cracked the head off the bolt that holds it in.. Its on there tight, but theres no head.. How can i get it out?, sumone told me drill it out, but not rele sure on how to do that
karuso99GT
136
St. Louis, Mo
Apr 30, 2007
  • Apr 30, 2007
If you remove the IAC (if possible), is there enough of the bolt sticking out to make a removal attempt with vise grips?
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Apr 30, 2007
  • Apr 30, 2007
remove the other bolt that's holding in the IAC, and take off the iac
then place 2 nuts on the stud, and remove the one that's closer to the IAC. the 2nd nut is to stop the 1st nut from coming out, and it'll all come out together.
00GTpony
162
  • May 1, 2007
i cant removie the iac, cause the broken bolt is threaded on both sides, its threaded in the iac and throttle body.. so its in there tight like a normal bolt. just with no head and cant access it
streethorse
1,042
Dallas Texas
May 1, 2007
  • May 1, 2007
You need to buy a set of taps called "screw extractor set"
First try to center punch the broken bolt. then drill into the center punch hole.
try not to hurt the threads of course. Then select the right tap from the
set and tap it in. put a wrench on it and turn counter clockwise, it will grab on
harder the more you turn it.
Stang|ess
Oct 18, 2003
941
Hawaii
May 2, 2007
  • May 2, 2007
wow, never knew they have threaded IACs.
try jbwelding on another bolt onto it so you can unscrew it, but before that try vice grips.
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
  • Gulftown980x
  • Jul 29, 2026
squeak93
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
