  • SN95 4.6L Mustang Tech
IAT Sensor Relocation?
  • Thread starter Thread starter Roblu98
  • Start date Start date Mar 6, 2008
R
Roblu98
94
East Fallowfield, PA
Mar 6, 2008
  • Mar 6, 2008
I have been reading that relocating the IAT senosor to discharge side of the supercharger will help with tuning. Is this true? If so will the sensor pop out under boost? thanks for the info!
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Mar 6, 2008
  • Mar 6, 2008
i used some RTV to keep mine in place. and yes you need to move it to the discharge side of the s/c since the s/c will heat the air as it is being compressed
spederman
732
  • Mar 6, 2008
they also make a threaded IAT sensor. that way you can drill a hole/thread the discharge tube and screw in the IAT sensor.
R
Roblu98
94
Mar 6, 2008
  • Mar 6, 2008
Where can I find a threaded IAT senor?
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Mar 6, 2008
  • Mar 6, 2008
any ford dealer. it is a lightning sensor
RandyStinchcomb
1,159
Randallstown, Md
Mar 7, 2008
  • Mar 7, 2008
..correct and here is the part # for the threaded IAT, as most have trouble looking it up, F6SZ-12A697-A and if they cant get you one, we have plenty in stock at @$28.00
SilverBullet00
1,150
Wichita, KS
Mar 7, 2008
  • Mar 7, 2008
How does that thread into 2-3mm of alumimum pipe? Do you have to weld in a bung for it?
And I was told to put it as close to the throttle body as possible.
blubullett
535
Modesto, CA
Mar 7, 2008
  • Mar 7, 2008
Put a nut on the bottom of it?
LaserSVT
3,542
233
Mar 7, 2008
  • Mar 7, 2008
Yeah having the IAT on the discharge side will give the computer a more accurate reading and should help any driving/idle problems. Gonna need to drill a hole in the pipe and weld a nut to it, should work tits
speed545
458
Montreal, canada
Mar 8, 2008
#10
  • Mar 8, 2008
  • #10
just threaded the discharge pipe with an NPT tap. It will be fine. just dont tighten it like crazy.
Mine s on for 1 year without any leak or what ever else
SilverBullet00
1,150
Wichita, KS
Mar 8, 2008
#11
  • Mar 8, 2008
  • #11
damn, is it a 3/8" NPT tap? I wouldnt thing there would be enough material for the tap to cut threads into. Maybe I will try to punch the hole to get extra material, like the oil pan??
speed545
458
Montreal, canada
Mar 8, 2008
#12
  • Mar 8, 2008
  • #12
Nop, just drilled into the pipe and it did the job.
R
Roblu98
94
Mar 9, 2008
#13
  • Mar 9, 2008
  • #13
I dont think you should try to punch Aluminium. I think that you would crack the pipe if you tried that. I was thinking if you drill the hole close to throttle body you should be able to reach in and put a nut on it.
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
ECU help!
  • starkiller1134
  • Aug 16, 2025
SN95 4.6L Mustang Tech Aug 17, 2025
starkiller1134
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
  • Gulftown980x
  • Jul 29, 2026
squeak93
