idel problems on a 1990 GT
:shrug: I have a 1990 GT and when the engine is hot and I have the a/c on the idel will run from 800 to 2000 rpm until the car amost dies can anyone help me on this. Also when the engine is hot the starter will drag when starting. I have already replaced the starter with a new one and still have the same issue I have also replaced the voltage regulator and the coil
I just fixed this problem on my 90 LX....
You have to make sure your TPS is getting the right amount of juice. I don't know the exact proceedure, but contact M8KMDAY (he did mine) and he will be able to walk you through the process.
I replaced my tps and this seemed to fix the idel issue with the cold start up but I also have another issue when you turn on the ac and the it kicks in it drops my idel down by 400 rpms and when the cluthc on the compressor disengages the idel comes back up to 800 do you know what part controls your idel when your compressor kicks on or what part idels your car up when your compressor turns on?
