Engine Idle cuts out
  • Thread starter Thread starter claypoolxx
  • Start date Start date Mar 7, 2026
First Prev 2 of 2
alutwon
46
May 30, 2026
#21
  • May 30, 2026
  • #21
interesting write up and It could very well be my issue. Mine only happens when the car is hot and stopped for a few mins leading me to believe it's heat soak of some type. I did the base idle reset and no change. the fuel pump and filter are next since I need to do it anyway.
General karthief said:
What are the gauges doing when idle drops?
they all dip like I turned the key off
Reactions: General karthief
alutwon
46
Jun 5, 2026
#22
  • Jun 5, 2026
  • #22
I finally captured a video of what's going on. this is directly after a new tfi and new coil swap. I drove the car for about 20 mins and it started doing this in my driveway after idling for around 7 mins. distributor is 3 years old.
Your browser is not able to display this video.
edit: ignore the oil pressure gauge reading so low, the connector needs to be replaced
KRUISR
1,897
1,034
143
Jun 5, 2026
#23
  • Jun 5, 2026
  • #23
CAMTWO1070 said:
Nobody really takes the time to realize the camshaft spins twice as fast as the crank
That doesn't make sense as the crank sprocket is smaller than the cam sprocket. The crank has to rotate twice for one revolution of the cam. So the cam spins half as fast as the crank..
alutwon
46
Jul 24, 2026
#24
  • Jul 24, 2026
  • #24
so I think I finally figured out what my issue was, I've been driving the car for 3 days and so far so good. first the battery cable going from my starter solenoid on the fender to the battery was a cheap Aluminum 4gauge for audio equipment. second my throttle blade was set too far open, I brought it down to about 500 rpms and reset the ecm. now the iac can do it's job, I think it was staying closed to compensate for the extra air.
JD1964
there is enough sticking out to grab on to
3,648
1,672
194
Maryland
Jul 24, 2026
#25
  • Jul 24, 2026
  • #25
Good battery cables are surely important. What type / size replacement cable did you use?
alutwon
46
Jul 24, 2026
#26
  • Jul 24, 2026
  • #26
still 4 gauge but this time actual copper
Reactions: General karthief and JD1964
First Prev 2 of 2
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
93 LX 5.0 - 2,000 rpm misfiring, stuttering, and bogging upon acceleration (videos)
  • dan50
  • Nov 14, 2026
Fox 5.0 Mustang Tech Nov 15, 2026
General karthief
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
5K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
