idle drops off at stop lights
Kurt
149
South Hill ,Va
When i have the car in gear the idle will start to drop of (lobe down, gradually decrease) and then cut off. the car will idel fine in park. what are some areas to look at.
Timming ?
vacum leak?
head gasket?
please direct
Kurt :bang:
What kink of carb are you running? My first guess is that the idle mixture is too lean. That does strange things to the vacuum signal, which (on my cars anyway) makes the vacuum advance start to back off, which eventually lowers the idle speed enough to kill the engine.
A little history I put to much silicone on the intake gasket causing the end seals to push out and I knew there was a vacum/ oil leak, so i fixed that and then posted thread, because the problem continuned.
I then replaced the spark plug wires as well as coil wire, when I removed the coil wire it broke of in the coil. I don't know why but afteri put the new wires on the problem went away.
