Idle Idle Idle
  • Thread starter Thread starter 1965-Mustang
  • Start date Start date Nov 5, 2005
1965-Mustang
85
  • Nov 5, 2005
I am having an idle with my car. I have figured out now that after WOT the car will idle at 2000 rpm. When I shut the car down and restart it goes back to 800-900 rpm. While driving normal it sometimes will start idleing at 1000-1300 rpm though. But mostly after a drive without hitting WOT it will stay at 800-900 rpm. Since it goes back to normal after I restart the car I am thinking this problem is not mechanical; nothing seems to be binding or hanging in throttle linkage. I thought it was a vacuum leak at first but wouldnt it idle like this all the time? What could this be? Ignition? I have messed with the carburetor more times then I care to. It is a Speed Demon and I have played around with every setting. I tried messing with the 'Idle-Eze' screw but I am not sure how/what it does. I am at a loss, any help would be very appreciated as it is extremely annoying with a 2000 rpm idle.
Thanks.
J
JB66
565
New York
Nov 5, 2005
  • Nov 5, 2005
Be nice if we knew the engine/carb/trans combo.
10secgoal
2,801
San Diego
Nov 6, 2005
  • Nov 6, 2005
Does sound mechanical. When it does this, have you tried to lift the pedal to see if the idle lowers ? Or you can try to partially disassemble to distributor and hit it with soem carb spray on the weights and springs. Maybe it's getting gumbed up and not letting the timing return to normal.
2nd Mustang
2,488
Southern California
Nov 6, 2005
  • Nov 6, 2005
I have the same thing happening on my 600 Holley. This is a new Holley, but same thing happened on my old one. Installed new intake gaskets, same thing. Made sure linkage and gas pedal weren't hanging up somewhere. Installed double return springs, same thing. I just blip the gas pedal when coming to a stop and it usually drops the idle speed, but sometimes not until I try a few times. The only other thing I can think of is maybe the motor mounts are bad and causing the motor to bind. The linkage is such a simple design, I know the answer is going to be a simple one.
red65
411
Ann Arbor, MI
Nov 6, 2005
  • Nov 6, 2005
Not the same carb, but could be the same problem -- the secondaries on my Holley 4-barrel on my old '85 5.0 used to stick just a bit open, resulting in a very high idle (around 2k). Solution was simple - disassemble, clean off the gunk, lubricate and reassemble. Works like a charm. Easy enough to diagnose, too.
1965-Mustang
85
  • Nov 6, 2005
This is exactly my problem...I aslo changed the intake gaskets, pulled up on the pedal to see if was caught, I have the return springs. And the blip of gas works for me sometimes too, sometimes not; just like you said. I have also taken the carb off and sprayed down with carb cleaner, not really thoroughly though. I will try the cleaning of the distributor and some more looking at the secondaries. Thanks so much!
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Monday at 4:37 AM
86HO5.0
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
