  • SN95 4.6L Mustang Tech
Idle Issue after IAC Mod
  • Thread starter Thread starter 00GTpony
  • Start date Start date Feb 5, 2008
00GTpony
162
  • Feb 5, 2008
So i made the IAC Gasket, so the revs drop quick..... The revs do drop quick, but now my car at a light is idling at likw 1100rpms... When it use to at like 800. Any ideas?..... i figured it was because i disconnected the iac so the computer would adjust to it, but i drove around for a while and it was still idling at 1100.
D
Dragstr05
643
Stafford VA
Feb 6, 2008
  • Feb 6, 2008
Check for vacuum leaks would be a good first step...they will cause high idle.
And remember that you did modify the component that makes your car idle in the first place. I know its supposed to "restrict" air, but you never know. You could try just taking that off and see if the idle goes back to normal.
9
99 GT vert
17
Ohio
Feb 6, 2008
  • Feb 6, 2008
my idle is different after i did the iac mod to but i have yet to drive around yet
joshheat25
871
Delaware
Feb 6, 2008
  • Feb 6, 2008
Why did you do this? put it back to normal.
  • Gulftown980x
  • Jul 29, 2026
squeak93
K
2003 GT High Idle, vac leak process
  • krysber
  • May 11, 2025
SN95 4.6L Mustang Tech May 11, 2025
krysber
K
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
