  • 1994 - 1995 Specific Tech
idle issue on my 94
  • Thread starter Thread starter Jaffman088
  • Start date Start date Oct 25, 2010
J
Jaffman088
14
  • Oct 25, 2010
hey, I am new to thread posting, but I am having problems with the idle on my 94 5.0. I'm not sure whether I am having an overdraw of power somewhere, but I have a problem with the idle getting too low, and most times with my headlights on and sometimes without them on, the power steering causes my engine to stall while idling. I'm hoping someone can help me out with this issue.
9
94GTMustang5.0
98
  • Oct 25, 2010
There is a screw you can turn to raise/lower your idle right by the throttle body. try adjusting it and see if it helps.
HISSIN50
34
129
Oct 25, 2010
  • Oct 25, 2010
Start with pulling codes. The CEL need not be on for codes to be stored.
If the car was running fine before, the IAC probably got gunked up and is the issue. Be prepared to replace the IAC but you can try to clean it first:
Ford Mustang IAC IAB - Solving your idle problems
Good luck.
skeptiq
26
Cincinnati
Oct 26, 2010
  • Oct 26, 2010
Good luck.
Quoted for truth.
This sounds like classic IAC issues... I have had my share of idle issues and what you are describing sounds like IAC trouble. The link posted is great! There are also other articles associated with that link that will walk you through the entire idle process and how to properly set your idle. Well worth the read and the work!!!
Good luck!
Ben
9
94GTMustang5.0
98
  • Oct 27, 2010
when my IAC went bad, my usual idle of 600rpms was fluctuating between 850-1000, which was very annoying because at around 1k rpm is when my flowmasters have that annoying drone :/
J
Jaffman088
14
  • Oct 27, 2010
I was told that the power steering switch causes the vehicle to overdraw power and cuases the idle to not go up causing the engine to stall.
HISSIN50
34
129
Oct 27, 2010
  • Oct 27, 2010
The idle doesn't increase with PS input. Smaller engines use this feature to prevent stalling.
J
Jaffman088
14
  • Oct 27, 2010
so you're trying to tell me that it is still an issue with the IAC as everyone else is telling me? or what is your thought on the issue.
HISSIN50
34
129
Oct 27, 2010
  • Oct 27, 2010
I mentioned in post 3 what I would do.
I was merely noting that there is no idle-speed modification for the PS on the V8's.
earleys94gt
1,223
Ashley, Ohio
Oct 27, 2010
#10
  • Oct 27, 2010
  • #10
More than likely, the sensors in the "air intake" track are dirty.
This includes the IAC, Idle Air Control, MAF, Mass Air-flow Sensor, etc.
Try and clean these sensors and see if they fix the issue, if nothing else you can eliminate these as possible sources.
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
