  • 1994 - 1995 Specific Tech
Idle Issue (Please Help)
  • Thread starter Thread starter SBC RACING
  • Start date Start date Oct 29, 2004
SBC RACING
141
Santa Barbara, Califonia
Oct 29, 2004
  • Oct 29, 2004
Well i have been having problems with my idle hunting up and down and the car stalling at intersections, so today i cleaned the IAC and throttle Body with no success. I disconnected the IAC plug and started the car and the car would not even idle. I could keep the car alive by giving it gas but as soon as i would let off the gas and the rpms came down the car would die.
Does this mean the problem is not the IAC? What could the problem be?
Please help me out thanks
SBC RACING
141
Oct 29, 2004
  • Oct 29, 2004
bump
Hef5.0weisen
20+ Year Stangneter
Mar 5, 2004
574
NorthWest Florida
Oct 29, 2004
  • Oct 29, 2004
replace the throttle position sensor, worked for me. good luck man
HISSIN50
34
129
Oct 30, 2004
  • Oct 30, 2004
what comes to mind. there are several factors which go into proper and correct idle. the throttle stop screw setting, function of the IAC, TPS, etc.
i would start at scratch and set it all up. if one component is out of whack, the other adjustments can be affected (i.e. throttle stop screw is not adjusted correctly). and if the idle is too far from stock, the puter will try to trim things it can to bring the idle back down.
have you pulled codes? dont omit ideas like a sticking EGR (allowing spent gasses at idle, which it should not), and things like that.
do you have good cold idle characteristics? how about when there is load (A/C on, etc)?
good luck.
HISSIN50
34
129
Oct 30, 2004
  • Oct 30, 2004
oh yeah, im not sure what any exact differences are in the idle setting from a fox to an SN, but here is a decent write up for foxes. each page has steps for all the adjustemnts i outlined.
http://www.muscularmustangs.com/iac.html
good luck.
RIO5.0
6,892
N.H.
Oct 30, 2004
  • Oct 30, 2004
good luck.
I have used the above link with excellant results...Like he mentioned, one affects the other...
Nik_95Cobra
1,677
Tempe, Arizona
Oct 30, 2004
  • Oct 30, 2004
Same thing happened to mine. I went through all the normal idle issue procedures to no avail. After that I sad fork it and I just bought a FMS 65mm T-Body which came with a new IAC and TPS...Bang...Problem was fixed. Good luck with it mang.
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
