  • 2.3L (N/A & Turbo) Tech
Idle Misfire
  • Thread starter Thread starter JamesBaumann
  • Start date Start date Apr 21, 2004
JamesBaumann
624
Vancouver Island
Apr 21, 2004
  • Apr 21, 2004
Once my car is warmed up, when I am stopped at a red light or at idle any time it seems to misfire. However, she goes smooth once I get moving and I am just at cruising speed and rpm's. Anybody have any ideas as to why this would happen?
T
Tru_Blue_104
218
MN
Apr 21, 2004
  • Apr 21, 2004
I have the same problem on my 89, I've heard it called a lean misfire. Try spraying starting fluid around the vacum lines, fuel injectors, egr, pretty much everywhere. Also, clean the AIC, and check the throttle posistion sensor. Do a search for threads with it, theres a ton. I've done all this and still havent figured it out. I may just bring it somewhere now.
JamesBaumann
624
Vancouver Island
Apr 21, 2004
  • Apr 21, 2004
Thanks for the help. What is this starting fluid stuff? Do you think it could potentially be the timing?
T
Tru_Blue_104
218
MN
Apr 21, 2004
  • Apr 21, 2004
Yes definatly, check it or have it checked.
Also, when was the last time you did a tune up? Like plugs, wires, cap and rotor (if you got them), PCV valve, fuel filter, air filter. Thats all i can think of, but if you havent done any of those, do them. And dont sink your money into those bosch plugs, just get the motorcraft ones.
JamesBaumann
624
Vancouver Island
Apr 21, 2004
  • Apr 21, 2004
I have recently put in plugs, fuel filter and air filter. Soon enough I am going to put on new 9mm Ford Racing Wires and a new cap & rotor. Right now the plugs I have in are Champion ones, so I will put in some motorcraft ones as well. Can you buy motorcraft plugs from your local Ford dealer? Because I dont know of any places around my little town where you can buy motorcraft parts. Also, everytime my car misfires at idle it makes a loud knock in the exhaust. I am also going to put in a new 02 sensor and see if all these parts make a difference.
T
Tru_Blue_104
218
MN
Apr 22, 2004
  • Apr 22, 2004
I forgot to mention the O2 sensor, if you havent replaced it, do it. With the timing, have you ever replaced the belt? If not, I'd suggest it, it will go out at the worst time. I've also heard that the CHampion plugs are the same as the motorcraft ones. But if you still want to switch them, which I reccomend, you can pick them up at any ford dealer. Also, if it were me, I wouldnt spend the extra money on the 9mm wires. If you dont have any ignition upgrades, ie MSD components, then it really is unessecary. I used 8mm wires on my stock system, and I actually noticed a decrease in performance. Id say go get yourself a set of motorcraft wires. BIG difference. Good luck! Let me know if you got any other Q's.
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
H
Misfire cyl 2 under 3200 RPM, not the coil or injector
  • Hydranmenace
  • Nov 14, 2025
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Nov 14, 2025
Hydranmenace
H
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
R
Misfire at high rpm! Help
  • Ryanm2018gt
  • Jan 2, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jan 17, 2026
highplace11
H
