Idle Problem w/ lights on
luckythirteen13 said:
maybe your alt is dying. is it stock? the factory alt. is a joke. i switched over to a 150amp alternator and i make 14v at idle even with everything running. does the car do the same thing when you run your stereo or a/c?
my radio's always on, alternator is 2 months old. It is pretty odd. And I dont have A/C
I would pull codes, given your hesitation issue too. An engine management issue could be causing a low idle/stalling and/or the hesitation.
Good luck.
