I've been having problems with my idle recently.
My current mods are:
- VT N/A Stage 1 Cams
- Mac Prochamber O/R
- Diablosport Predator
- GMS Upper Intake Plenum
- Steeda U/D Pulleys
- BBK 75mm Throttle Body
- FRPP 3.73 Gears
- Street tires (Exclaim UHP)
- Bullitt Suspension Kit
- SVT Cobra Front Brakes
The idle will drop close to 500rpm then will jump up to 1200rpm then settle. It will do this 1-2 times in a row trying to set the idle. Now before you say IAC valve, I just changed it 2 hours ago and the problem is still there.
I checked for leaks, nothing.
The car will idle perfectly, but when, at a stop, I give a bit of gas rising the RPM to 1500 and let go, the rpm will drop to 1000rpm stay for 0.5sec then drop to 500RPM. This is where the motor kicks it up to 1200rpm to settle the idle.
The car will idle forever with no problem, it's only coming to a stop when the rpm is going or when parked giving gas. My idle is set at 850rpm
Any clue?
What I've done so far:
- Replace IAC with new Motorcraft IAC
- Checked for vacuum leaks
- Reset ECU
- FRPP 3.73 Gears
Any clue?
- Reset ECU
