Idle problems... you should read!
  • Thread starter Thread starter DMAN302
  • Start date Start date Nov 3, 2004
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Nov 3, 2004
  • Nov 3, 2004
I thought I knew my engine bay like the back of my hand, and was blaming my idle surging and stalling problem on the H/C/I I had put in. For about 2 weeks I was doing the idle reset and having good results initially but only to have the problem pop back up. Idle would surge and die, hang high 1100-1200, and surge stall when comming to a stop. I tried every approach setting the idle at 1000 and even 700 with poor results, tried setting TPS at all different settings too. Finally I spent some SERIOUS time just following vac lines and learning where they when and why, and that's when I found my problems...wish I could narrow it down to one thing but I found a few. First I discovered the orange hego ground was not connected (now it is), next I found my PCV grommet was not really snug so pulled it and inserted the PCV into it the grommet and wrapped the outer dia of the grommet with electrical tape to get a nice tight fit into the lower manifold. Next and my favorite..I after going over the vac lines 5x I found a broken line just inside my passenger fender well and replaced it . The result is....850-900 idle with no surging and computer is compensating nicely on the RPM's as they drop with NO SURGING and NO STALLING, the idle is lopey as it should be with the XE270hr-12 but is reliable and comes to a stop with good RPM manners. This is a long story but I hope someone out there with a simular problem can find some useful info to help them out. I have spent probably 20-30 hours under that hood over the last 6months swapping the engine, painting the bay, trying to tune, and I NEVER saw the problems. Spend the time going over these simple basics and you may end up saving some serious coin by not trying to throw money at the problem..could be a piece of tape and vac hose is all you need. Again sorry for taking up so much space. Oh and by the way I took my baby out tonight again and with the new set up finally runnig properly I let her have it to about 5000 in 3rd..um all I can say is my car was SLOW with the old motor, now it feels like it weights half as much as it did cause the RPM's just hammer up the tach and you can FEEL it put you in the set like never before..I look foward to some full throttle blasts to 6000 in a few hundred miles BIG TIME.
HISSIN50
34
129
Nov 3, 2004
  • Nov 3, 2004
nice post.
im glad to hear you got it purring like a champ.
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Nov 3, 2004
  • Nov 3, 2004
Thanks HISSIN50, I can tell you that in the past you and Mr Yount have been most helpfull to me, I guess I just feel we need to share more of our problem solving on the site rather than just our problems.
HISSIN50
34
129
Nov 3, 2004
  • Nov 3, 2004
thanks for the kind words. right back atcha'
you are right on. as you have probably found, there is not enough feedback from posters about what the cure was and/or how it was accomplished. with some advice i give, it is from experience; other advice is my warped logic or something i have come across but never had personal hands-on experience with. it is always nice to know what works and what doesn't (i like to know if the advice i gave was in the ballpark. ).
i have done the same things you did (look at stuff till you cant remember your own name). go over things time and time again. do it until you are so confused you dont remember any results from earlier testing. LOL.
often, it is the way to find myriad little things which cumulatively create noticable running issues.
again, nice work and thanks for the info.
shewitt
85
Newnan GA
Nov 22, 2004
  • Nov 22, 2004
Thanks for the info im happy to see when someone fixes the problem and then comes back to let everyone know what your problem was. Im going to start looking at all my vac lines to see if that is what my problem is.
89white50
440
central MA
Nov 22, 2004
  • Nov 22, 2004
i second the motion, that sounds exactly like the problem i have, i have done some serious work on the motor of lateand the pcv vavle not fitting snugly i also noticed. Thanks for the heads up
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
