  • SN95 4.6L Mustang Tech
Idle Question
  • Thread starter Thread starter vvzer0incvv
  • Start date Start date Jan 20, 2004
V
vvzer0incvv
133
Carol Stream, IL
Jan 20, 2004
  • Jan 20, 2004
My 96 GT 5spd has the typical slow dropping rpms, but it seems that i never can get any lower than 1000rpms. I let the car warm up for like 15mins in my heated garage and the idle was steady at 1000rpms, this can't be right. Is there any way to lower my idle? I just went and bought some copper caps to take car of the slow drop, i just would like to know if i can get the idle a lil lower. Thanks
v8thunder1
33
  • Jan 20, 2004
You may have to adjust the throttle position sensor (TPS). I think its supposed to be around .98-.99 volts with the car off, but the ignition on.
Graham052
193
  • Jan 20, 2004
:OT: sorry, what are these copper caps you speak of?
krly79
464
VA Beach & So Illinois
Jan 20, 2004
  • Jan 20, 2004
though I thought it was around .96 to .98/.99
If you put a 1/2in copper spacer in the hose between the IAC and the black box, w/ a 7/16 or 9/16 (cant remember which one) hole drilled in the center, it will make your idle drop a little faster. It still doesn't drop it as fast as I'd like, but it does help.
9
97 Stang
34
  • Jan 20, 2004
Hey, there's an idle screw located on the throttle body. If you are looking at it from the passenger side fender then you turn the screw to the right to lower the idle. There's no head on the screw so just get some pliers to rotate it, make sure you don't mess up the threads though.
V
vvzer0incvv
133
Carol Stream, IL
Jan 20, 2004
  • Jan 20, 2004
I'll try that...i tried to to turn it to the left but it didn't do anything so i'll try it the other way.
Anyone know how to adjust the TPS?
krly79
464
Jan 20, 2004
  • Jan 20, 2004
You have to measure the voltage with the car on, but the engine OFF. You measure off 2 of the wires on the TPS, but can't remember which ones. You have to unscrew the two TPS screws (Good Luck with that one) and rotate it one way or the other to achieve the .9x (cant remember that exactly either) v8thunder thought it was .98 to .99, I thought it was like .96 to .99 or somehthing. I say if you go .98 you'll be fine. You might have to elongate the holes on the TPS abit to achieve this though.
Anyone know which wires?
V
vvzer0incvv
133
Carol Stream, IL
Jan 20, 2004
  • Jan 20, 2004
Thanks everyone for you input....anyone else? Any more detailed info? thanks
  • Gulftown980x
  • Jul 29, 2026
squeak93
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
