Idle related
  • Thread starter Thread starter dwhiskie
  • Start date Start date Aug 2, 2005
D
dwhiskie
183
  • Aug 2, 2005
Ok, my car idles pretty good at 1000rpms but when I turn on the headlights the idle goes up about 400rpms and stays there untill I shut the lights off then it goes back down to 1K. I cant figure out why anything electrical would influence the idle. Any ideas??-All my grounds are good.
Black 93 Fox
1,995
Vancouver,Washington
Aug 3, 2005
  • Aug 3, 2005
Cause the motor is put under more load. It has to spin the alt faster to make more power which raises the RPM's. I wouldnt expect it to raise 400 tho.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 3, 2005
  • Aug 3, 2005
Possible bad alternator power ground or low output from the alternator.
The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges. Any car that has a 3G alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects.
K
88 speed density misfire and bucking
  • kush
  • May 29, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
DadLife0724
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
5K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
