im starting to work on my maf transfer and tb airflow & isc in EA but want to make sure im starting out with the right settings. my desired idle is 850. if i have idle in drive and idle in neutral set to 850 what would i put in for the isc max rpm in drive and isc rpm at CT? are those the only initial changes or does anything else need to be changed as far as idle? also when i try to datalog for the tb airflow & isc the car will die when i unplug the iac. i have the set screw one turn past closed and the iac two turns out. should i not touch those at all or will i have to mess with them to get the base idle?
