  • SN95 4.6L Mustang Tech
idle/stall problem CMS STAGE 1 CAMS
  • Thread starter Thread starter rispoli_23
  • Start date Start date Apr 22, 2010
rispoli_23
182
  • Apr 22, 2010
hey guys i need help i have had idle/stall problems ever since i have had my cams installed everytime i have a tech look at it it seems to be the iac valve... if i change the current one i have that will be number 3 in the last 2 years ... is this common on these cars with cams or is there something else going on and this is just a temp fix ???? i also just had the car dyno tuned about 2 weeks ago and it ran good for a couple days then the check engine light came on with p0300 and p0602 i called my tuner he said clean my maf sensor, did that and the light went off and then my idle problems started, i let him know and he is trying to work me in to look at it but i checked my iac valve like i always do and it seems to acting the same way the last one did when it went bad .... any suggestions
thanks
richard
rispoli_23
182
  • Apr 22, 2010
also guys i have noticed i am getting wich to me looks like a lot of oil into the intake plenum where the pcv valve hose runs into the plenum ... is that normal for a car that only has cams ?? my car is a 99 gt with 80,000 miles on it but i noticed the oil around 60k when i had the cams installed
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
  • Gulftown980x
  • Jul 29, 2026
squeak93
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
