IDLE?TPS?SURGEING
  • Thread starter Thread starter 90lxnotch
  • Start date Start date Mar 23, 2004
9
90lxnotch
23
slc, utah
Mar 23, 2004
  • Mar 23, 2004
im hopeing someone has some answers to my question i have tfs tw heads 306ci tfs stg 2 cam tfs track heat intake c&l maf 76mm calibrated for 24lbs inj,75mm tb 24lb injectors im having a surge its when my tps and iac is plugged in but when its not it idles fine i have all new sensors i even have the iac idle adjusting plate but surges but if i have my iac and tps in i can unplug my o2 sensor harness and then it idles fine but when its plugged in it surges my tps is set at .91 i cant adjust anymore unless i mess to much with the throttle stop i have a a9l computer please help oh and its got 190lph fuel pump
9
90bluegt
592
  • Mar 23, 2004
You have to get that TPS in the .94 to .99 range.
shawn13
70
Dwight IL
Mar 23, 2004
  • Mar 23, 2004
that tps will screw you if you dont have it set in the guild lines
9
90lxnotch
23
slc, utah
Mar 23, 2004
  • Mar 23, 2004
do i mess with the throttle stop
NYC LSC
626
Staten Island, NYC
Mar 23, 2004
  • Mar 23, 2004
Not if you don't have to.
Just elongate the holes in the TPS to get it set to where you want it. Also, if the car doesn't surge with the IAC disconnected, I suggest either cleaning or replacing it.
Good luck.
9
90lxnotch
23
slc, utah
Mar 23, 2004
  • Mar 23, 2004
i did oval out the holes and i could only get it to .82 and i have a new iac
M
matm347
2,056
  • Mar 23, 2004
unplug the IAB, set your idle around 600 with the screw. Then plug the IAB back in, if it still surges set your TPS to ~4.5@WOT, you should be good then unless a sensor or two needs to be replaced. You shouldn't have to adjust your idle with the screw(and IAB plugged in), but many people want a higher idle to keep the vacuum up with larger cams.
9
90lxnotch
23
slc, utah
Mar 26, 2004
  • Mar 26, 2004
well i called ford racing today he told me to reset the idle so i followed waht he sent me and it still surges i have checked all the vacum lines no leaks whats up with it i got my tps at.99 with the idle around 1000 but then it surges and sometimes dies
Luvmy88
136
  • Mar 26, 2004
Metoo
I have the same problem.
Wont help but at least you're not the only one
87'GTstang
1,025
#10
  • Mar 26, 2004
  • #10
Sure you have no vaccum leaks or gasket failures anywhere (considering that's the number one smooth idle killer)?
N
noslow5_0
422
dallas tx.
Mar 26, 2004
#11
  • Mar 26, 2004
  • #11
check agian and again for any VACUM LEAKS!!! i had about 5 million of em' on mine, and didnt even know it!!!! thought that the carb cleaner thing would for sure tell if one was present, but it didnt... finally i just capped of any accesories that were off of the vacum tree!!! upon hiding the wires on my passenger side engine bay, i seen that everyone of the egr vacum lines where all cracked to h***. o well you live an learn i guess... just check for another one, cause i almost guarntee thats what it is!!!
Schlodes
354
Lidsville.... West side dawg..
Mar 27, 2004
#12
  • Mar 27, 2004
  • #12
I keep my TPS set close where the factory had it.. I think its at about .87v now. I used to set it up in the high .90s I've heard if yer gonna do this not to go higher than .95 or so, otherwise the ECM thinks the throttle is open a tad and the IAC compensates and makes it idle high... my car would never idle rightthat way, so I put it back to where it is now.
Myself, I think the TPS mod is a do not do. I mean, what voltage does the EEC need to see in order to go into PE mode [power enrichment mode was what is was called in the T Types ECM when you went WOT, and "PE" voltage was only like 2.6v I think] because as long as your getting that... which they do from the factory, untouched, then you're good.
What i'd be more worried about.... Have a buddy floor it inside the car and observe the throttle plate inside the T body, and if it is infact going all the way open. I remember reading in MMFF that that was one thing that was wrong with some of the 5.0s is that they dont get actual full throttle..
9
90lxnotch
23
slc, utah
Mar 27, 2004
#13
  • Mar 27, 2004
  • #13
but why when i unplug the tps and iac it dont surge but when its plugged in it surges
Schlodes
354
Mar 27, 2004
#14
  • Mar 27, 2004
  • #14
This is what I saved a while back... I think I found this on the Corral....
The "idle screw" that everyone is referring to is actually a throttle stop. It was never intended to be used to adjust the idle because the computer is designed to control the idle to a preset level programmed into the ecu - 672 rpm. It does this by monitoring rpm and telling the IAB solenoid to let more or less air bypass the throttle plate to stabilize the speed. While some folks have luck setting the idle speed higher, just as many only create a machine that constantly surges and hunts for a constant idle speed as the computer "fights" with your attempts to increase the idle speed by turning the throttle stop screw. You should also reset your tps level down to .95V or lower - having it up around 1.0V (.99V) can also cause the idle speed to do funky things. If the idle problem appeared NOT as a result of other changes you made I'd try this:
1) remove throttle body and iab solenoid and clean them thoroughly; reinstall
2) Set the throttle stop back to its proper location - back it completely off (unscrew it); place a .003 feeler gauge between the screw tip and the throttle arm; tighten it til it just touches the feeler gauge; then remove the feeler blade and tighten it 1/4 turn more.
3) Set your tps to .95V with the ignition on/engine off but warm
4) Disconnect the battery with the headlights turned on - leave it disconnected with the headlights on for a minute or 2.
5) Reconnect the battery and crank it up. During the next few hours (cummulatively) of driving the computer should 'relearn' and begin controlling the idle with more stability.
Good luck!! Chasing down funky idle issues is one of the toughest things the efi crowd deals with.
Worked for my car for the most part. I surge a bit when the car is warming up, but its fan wash from the clutch fan air hitting my cone I think... and after it warms up to temp, still its pretty steady on my car
9
90lxnotch
23
slc, utah
Mar 28, 2004
#15
  • Mar 28, 2004
  • #15
i tried doing that and it didnt work do you think it could be my cam or would a computer chip fix the problem
T
Thunder5.0
142
#16
  • Mar 28, 2004
  • #16
I agree. Thoroughly cleaning the TB & IAB should solve your idleing problem. A lot of crud builds up in this area and can wreak havoc on your idle.
My stang idles steady at 700 with SC/H/I.
T
Thunder5.0
142
#17
  • Mar 28, 2004
  • #17
9
90lxnotch
23
slc, utah
Mar 28, 2004
#18
  • Mar 28, 2004
  • #18
its got a brandnew intake tb,iac everything is new on it
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
