Ignition Cylinder
Remove the ignition switch lock cylinder.
Insert the ignition key and turn to the RUN position.
Using a 1/8-inch drift, press the ignition switch lock cylinder release pin through the access hole while pulling out the ignition switch lock cylinder.
To install, reverse the removal procedure.
Verify ignition switch lock cylinder operation.
the release pin a a hole under the column right below the cylinder.
