R robertdale New Member Jan 31, 2002 382 0 0 kentucky Oct 8, 2007 #1 Oct 8, 2007 #1 I need to replace the ignition switch on my brothers 88 gt. Problem is that the harness that plugs into it has melted and need to be replaced. Does any one make a replacement part?
jrichker StangNet's favorite TOOL In Remembrance. Thank you for your contributions Mar 10, 2000 27,512 2,813 234 Dublin GA Oct 9, 2007 #2 Oct 9, 2007 #2 Other fords of the same vintage use the same switch. You might just get by with only replacing the connector shell. Some vendors other than the obivious junkyard source.. http://www.50resto.com/ https://fordparts.com/acc/ http://www.mustang-unl.com/lmparts.htm Wiring parts and connectors http://fordfuelinjection.com/products.html online Mustang junkyards http://www.stangparts.com/ Diagram courtesy of Tmoss & Stang&2birds View attachment 357761 See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Ignition switch wiring http://www.veryuseful.com/mustang/tech/engine/images/IgnitionSwitchWiring.gif Fuel pump, alternator, ignition & A/C wiring http://www.veryuseful.com/mustang/tech/engine/images/fuel-alt-links-ign-ac.gif Computer, actuator & sensor wiring http://www.veryuseful.com/mustang/tech/engine/images/88-91_5.0_EEC_Wiring_Diagram.gif Fuse panel layout http://www.veryuseful.com/mustang/tech/engine/images/MustangFuseBox.gif Vacuum routing http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxFordVacuumDiagram.jpg
R robertdale New Member Jan 31, 2002 382 0 0 kentucky Oct 9, 2007 #3 Oct 9, 2007 #3 Thanks I was hoping I could use one from the junkyard.
