  • 2005 - 2009 Specific Tech
Ignition on HOT wire inside car??
  • Thread starter Thread starter stang8urimport
  • Start date Start date Oct 29, 2006
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Oct 29, 2006
  • Oct 29, 2006
I seriously probed all day to find a damn ignition on hot wire inside this car to hard wire the Passport 8500. Where the hell can I find one on my 07?!?! HELP lol
anthony05gt
1,262
Maryland
Oct 29, 2006
  • Oct 29, 2006
I don't know if the '07 is the same as an '05, but on the '05 model there is a connector at the key switch with 6 wires going to it. The connector is set up for 7 wires, but only uses 6. Wire #6 is the black/pink one second from the end of the plug connector. It has voltage supplied while key switch is in run or accessory and is overload protected.
GOLDENPONY
1,503
LOVELAND, OHIO
Oct 30, 2006
  • Oct 30, 2006
Hot Wire
I found a better way to hook up my 8500. Inside the fuse box (pass side foot well) are two unused places on the block. One is switched, one is hot all the time. Mine comes on with the switch.
D
donnyonee
64
  • Nov 1, 2006
under the cover on the interior lites my the interior mirror, is where i found my 12v source. its always hot till about 15 min after you shut down the car, then it goes off all by it self.
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
R
electrical plug identification
  • redlineracing1328
  • Jun 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 12, 2026
keel
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
