Ignition Problem....Maybe??
  • Thread starter Thread starter napedawg555
  • Start date Start date May 29, 2008
N
napedawg555
Born in MI, live in NY but stationed in Afghanista
May 29, 2008
  • May 29, 2008
I have a 91 5.0. Not too many mods mainly bolt on stuff. I have a BBK SSI Intake w70mm Throttle Body and 76 MM MAF, MAC Full legnth head, MAC PRO Chamber, MAC Dumps,24lb injectors, 155 fuel bump, underdrive pulleys, a/c dead pulley and MSD Blaster Coil. I just started the car last night and set the timing to 14 degrees. I took the car around the block and noticed that one I can't get full throttle and two when my tranny shift into 2nd gear the car starts to shake really bad. It also sound like I have multiple detonations. I am stumped almost to the point of taking it in. Any suggestions?
Vipersix
434
Clarksville, TN
May 30, 2008
  • May 30, 2008
Have you replaced anything or done any major repairs recently?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 31, 2008
  • May 31, 2008
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
J
For Sale [FOR SALE] 1991 Mustang Notchback / 90,000 Miles / ~15,000 mile motor / Lots of Upgrades
  • Johnnie_Casino
  • Apr 2, 2025
Fox Body Mustangs For Sale (1979-93) Apr 2, 2025
Johnnie_Casino
J
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
