Ignition Problem
roworld
105
baltimore md
Im having a problem with my 88gt. sometimes it wont rev pass 4k and starts to back fire from the exhaust even while im driving. If I cut the key off then right back on it goes way. I just did the mass air swap and its the same if not worst. Im thinking maybe its a ground problem. How many grounds are under the hood and where are they located. Has anyone else ever had this problem.
The TFI module mounted on the distributor is usually the culprit for a high speed miss on a warm engine. If the problem does not occur when the engine is cold, the TFI module is definitely suspect. You may need a special socket to remove the TFI module, but most auto parts stores will have one for $5-$7.
Be sure to use plenty of the heat sink grease on the new TFI and clean the old grease off the distributor.
See Automotive Tools Specialty | Auto Mechanic & Technician Diagnostic, Testing Equipment | Thexton
