Ignition Problems...Help
  • Thread starter Thread starter fasttback
  • Start date Start date Mar 6, 2007
fasttback
471
Northern CA
Mar 6, 2007
  • Mar 6, 2007
Car was running fine, but I needed to adjust the valves. I decided to use the firing order method to adjust the valves. To turn the motor over I used a remote starter switch. Disconnected the coil wire to prevent fire up and started adjusting valves one cylinder at a time.
Adjustment went fine meeting hot lash specs for the cam. No other adjustment was made to the car. Reassembled and tried to start car. Car turned over with no signs of ignition through many attempts. I pulled a plug wire and spark plug and grounded it to the engine compartment...no spark.
Thinking I did something to the coil (Petronix) I switched it out with my Mallory Pro Master. No change. Next, I figured I did something to the electronic distributor (Mallory Unilite), and switched it out with another I had in the garage. No change. I will go through Mallory's trouble checklist next, but I was hoping someone would know what I screwed up this time.
T
toolwench
21
Los Angeles area
Mar 7, 2007
  • Mar 7, 2007
Is it possible that either the coil or distributor that you swapped in were bad, too? Definitely go through Mallory's troubleshooting. It's pretty straight forward.
I don't know how adjusting the valves could cause a no-start problem.
Is there a chance your coil wire has a break in it? Or maybe wasn't pushed back on all the way?
Is there a chance your ignition switch is worn? When mine finally wore out, it made the car hard to keep running without jiggling it, but I do recall it starting at least.
M
madbrad
72
Albuquerque NM
Mar 7, 2007
  • Mar 7, 2007
Check your coil wire, it might br bad. SOunds like a odd situation which in my experiance it normally something simple.
tos
896
68
59
Cincinnati Ohio
Mar 7, 2007
  • Mar 7, 2007
Did you remove either of the small wires off the coil initially? I would first check to see if you have power coming into the coil. To do this turn your ignition switch to the run position and check for 12 volts at the small wire on the positive side of the coil. If there is no power or very low power then work backwards from there. You can bypass your solenoid and run a wire direct from your pos side of the battery to this positive post and get it started also. My guess would be its no power into the coil or your coil lead itself got damaged when you pulled it out.
fasttback
471
Northern CA
Mar 7, 2007
  • Mar 7, 2007
I checked everything mentioned in the previous posts and also visited a Mallory troubleshooting web page. Looks like I spiked the module on the distributor??? Weird thing my second Mallory distributor had the same problem, but no remote starter was used with it. The rest of the wiring (coil, ballast, ground) is the same as it was for years with no problems - so I can't explain how the second one went out?
R
Roddster67
134
Lake Forest, CA.
Mar 10, 2007
  • Mar 10, 2007
I was tapping the starter with the solenoid when I was doing something to my car ( I don't remember what at this time), and it blew out my Pertronix module. Instant junk. This was the first generation Pertronix (from 1991 or so, blown out a couple of years ago).
fasttback
471
Northern CA
Mar 10, 2007
  • Mar 10, 2007
Yea, these electronics unit are very sensitive to just about anything. Before charging, jumping, welding, etc. disconnect the distributor. I'm surprised my first one lasted over 15 years without any problems.
I ordered a new module from Summit on Thurs morning and it arrived on Friday afternoon. Installed it Friday night and the car fired right up! This time I followed Mallory's complete setup and hoped for the best.
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
