Ignition problems?
  • Thread starter Thread starter stangb0i
  • Start date Start date May 14, 2004
stangb0i
Canada
May 14, 2004
  • May 14, 2004
Hey, im having some trouble getting my car started ('88 5.0). Im not getting any spark when i turn the key (batt, fuel pump, starter are all ok). I have replaced the dist rotor, cap and still no spark to get her going. Any idea's? any help would be appreciated
ss93cobra
1,422
Wilmington NC
May 14, 2004
  • May 14, 2004
Do you have power at and coming out of the ignition switch? What about the starter solenoid? The ignition module? Does the car have an aftermarket ignition system?
a_turbo_stang
346
Cincinnati Ohio
May 14, 2004
  • May 14, 2004
Try seeing if you have spark coming from the coil to the distrivuter. Then check for spark from the distributer to the plugs. Could have a bad module on your distributer. They tend to burn out on these mustangs.
cjones
1,561
Avondale, AZ
May 14, 2004
  • May 14, 2004
also, do you have 12v at the coil with the key on??
HISSIN50
34
129
May 14, 2004
  • May 14, 2004
all good advice. might pull codes to see if it tossed one. also, the infamous Jrichker list could help with checking stuff systematically.
good luck.
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
May 14, 2004
  • May 14, 2004
The TFI module could have went out on you. Take it off and have it checked at the parts store.
HISSIN50
34
129
May 15, 2004
  • May 15, 2004
check out the parts of the list that apply for you (courtest of Jrichker). good luck,
http://forums.stangnet.com/showpost.php?p=4152666&postcount=8
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
  • brandyn200
  • Jun 20, 2026
AeroCoupe
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
