Ignition problems
  • Thread starter Thread starter PC Dreams
  • Start date Start date May 25, 2004
P
PC Dreams
  • May 25, 2004
I've got a 67 mustang and I can't get it started. its got a 351w in it.
here is the story.
It was hard to start (but would start) about a week ago. I had to replace the starter (bad bendex) and replaced the starter to relay cable as well as the battery cables.
After this It would not start. It has a Mallory coil,distributor, resistor on it.
I checked for gas, no problem there. Spark at the distributor and plugs. Had to replace the pickup module (improper voltage, no drop). Firing order is correct. Cap and rotor looks ok. fuel filter is new.
no fuses blown.
it cranks but never turns over (sounds like it's not getting spark but it is)
Anything else I'm missing? Or is it time to start looking at timing?
One thing that is concerning me is I think I have a short somewhere (who knows where) because when I turn the key to run my tac jumps all over the place (as if you were reving and letting off the gas)
J
jesserose17
219
Southern CA
May 25, 2004
  • May 25, 2004
I would disconnect the tach wire and try if that will help. How do the plugs read - are they black & wet? If so, the carb could be running very rich.
P
PC Dreams
  • May 25, 2004
argg
still no go.
plugs were black but dry.
P
PC Dreams
  • May 25, 2004
argg
plugs are black but dry...
still no go
J
jesserose17
219
Southern CA
May 25, 2004
  • May 25, 2004
That means the carb is running real rich. I would either clean the plugs or get a new set.
P
PC Dreams
  • May 25, 2004
Just cleaned them. Think I may get some new ones and give that a shot..
P
PC Dreams
  • May 26, 2004
ok new plugs & plug wires have been installed. Nada
Max Power
1,774
St Paul
May 26, 2004
  • May 26, 2004
Do ypu have spark?
Do you have fuel?
Is it timed correctly?
J
jesserose17
219
Southern CA
May 26, 2004
  • May 26, 2004
Check the voltage at the coil input - make sure you are getting at least 6-9V with ballast resistance or 11-12V without with the key in on and start position.
P
PC Dreams
#10
  • May 26, 2004
  • #10
hmm
I have fuel, I have spark
I don't know how to check the timing without the car running..
I know the firing order is correct.. what else do I need to check?
P
PC Dreams
#11
  • May 26, 2004
  • #11
Update. I was wrong... I don't have spark.
I cranked it for about 5 mins (15 sec burst) and only got spark once.
what to check?
voltage at coil input is 9v (I have the ballast resistor)
69PaleHorse
264
Ventura County, CA
May 26, 2004
#12
  • May 26, 2004
  • #12
Well, there's not much left to check at this point. Check from Coil to distributor. If that's good, then there is a problem from distributor to plug, and since you have new wires and plugs it is unlikely that it would be them. So it is either a problem at the coil or dizzy, IMO.
P
PC Dreams
#13
  • May 26, 2004
  • #13
oh man
ok its getting fire from coil to distrib but not to the plugs. Just put a new module in and it test ok. No idea what else it could be.
I've even got an old distrib (vacume advance) I dropped in. Nothing.
Max Power
1,774
St Paul
May 26, 2004
#14
  • May 26, 2004
  • #14
Did you remember to put the rotor in?
P
PC Dreams
#15
  • May 26, 2004
  • #15
ROFL
Yes
J
jesserose17
219
Southern CA
May 26, 2004
#16
  • May 26, 2004
  • #16
Only thing I can think is the cap & rotor... if they're replaced and doesn't help, then it's likely something else. Check the compression and make sure the cam timing chain is not jumped.
P
PC Dreams
#17
  • May 27, 2004
  • #17
getting close
well the old dist I dropped in didn't work. Put the Mallory back in but f'ed up the timing (probally a tooth or two off). I'm going to replace the cap and rotor today and see what flies.
anyone happen to know what the timing should be on this?
351W out of a 77 tbird.. haven't been able to track it down on the net
390Fe
236
Pottstown PA
May 27, 2004
#18
  • May 27, 2004
  • #18
It sounds like you've stabbed the distributor a few times - any chance that the rotor is not pointing at the firing cylinder? er - what I mean is, even though your firing order on the terminals may be correct, it is possible for your rotor to be pointing to say the # 6 position instead of #1. Set your engine to TDC on #1 compression stroke - take off your cap and see if the rotor is pointing to the #1 plugwire. If not either re-stab the distributor so the rotor is pointing to # 1- or take the easy lazy way and reorder your plugwires to match your rotor position.
I know its a shot in the dark but I think it might be worth checking. Oh, also- did you replace the hardware on the vac secondary distributor? Points and condenser? Condensers are known for going bad just sitting - You can also check for spark at the points by moving them with a flat tip screwdriver and the ignition on.
P
PC Dreams
#19
  • May 27, 2004
  • #19
My GOD
Its alive
thanks for the help guys. Turns out it was the rotor and bug. Fires up better than ever now
J
jesserose17
219
Southern CA
May 27, 2004
#20
  • May 27, 2004
  • #20
Great! Glad we were able to help you!
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
F
1986 mustang no start
  • foxyjamss221
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
foxyjamss221
F
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
