My ignition switch went out recently...I changed the switch out and it fired up but was running rough so i cut the stang off...Well a few seconds later it tried to crank on its own, so i pulled the positive cable off the battery...While doing so i notice that the small ground wire that bolts to the side of the firewall and goes to the battery negative was hott and started to melt....So i checked the ignition switch connector and it had a crack in it, i changed the connector out, but the small ground wire that i stated earlier is still getting hot for some reason and the car is not getting power through the switch after installing another new one again....Any help would be much appreciated!!!!!! Thanks
