It is really simple... on the underside of the steering column, is a hole that is centered beneath the Ignition key cylinder. Insert a thin screwdriver and press, while turning the key in the key cylinder.. it will release the whole ignition key cylinder, then slide the replacement in. You can pickup a replacement ignition key cylinder for about $25 bucks at most auto stores.
Jim
