- May 13, 2006
- 26
- 0
- 0
Is the ignition switch mounted on the steering column also known as the ignition relay? If so how much do one of these cost? Im thinking that the problem with my car could be a bad ignition switch. I can take it out for a routine drive and the car starts bogging and stuttering at the exact same spot after about 20 minutes of driving. If I stop and allow it to idle, the car will die and will crank but not start for about 10 minutes. Then upon restarting it will run very poorly if I did not wait very long and die and repeat the same process.When it restarts after several minutes it will run like crap the rest of the way home, with occasional bogging at low rpms forcing me to keep them around 3k. Could a failed ignition switch be the culprit? Ive replaced TFI and checked for arcing, replaced FPR, Ive checked pressure when this happens by pinching the valve, fuel spews out for about a half second, but also spews out the same as it did when it isn't acting up, and I have a guage on order to be sure. When acting up, the pump makes an odd grunting like sound instead of the regular smooth priming sound.Ive also pulled codes. I get two opposite 02 sensor codes for the same sensor so I assume one is bad, but it could not cause my problem I don't think as the entire engine seems to be quitting instead of one side. The other codes I get are 87 and 96. Ive tested for voltage at the relay,inertia and main harness to the pump, they are all within spec. Id appreciate any input, but now I suspect the ignition switch if it's not the pump.
