ignition wiring help
1991notchbackLX
1,483
47
48
New York
okay, here's the deal... i'm going to be installing a custom push button start in my car, for the sole reason that I think it's cool and no one has ever done it in a fox before to my knowledge... i need a ground, 12V power source, and i have to wire one terminal to the "ignition start" wire
can anyone provide a wiring diagram or just specify which color wire in a 1991 LX is ignition "start?" where can i access the wire? i'm guessing there's access to it in the steering column somewhere near the ignition switch... any help is greatly appreciated
also, do you think i'll have any trouble with the neutral safety switch? i'm guessing as long as i have the clutch pressed down the car should start when the button is pressed, right?
Chris :nice:
thanks! okay so it looks like this one is what i need
so... which wire is it? :scratch: is it the red with teal stripe?
Not to disappoint but simply to inform:
it has been done before and it's kinda redundant if you need your key in the ignition anyhow.
yeah, i understand that it's been done by someone at some point, these cars have been modified to the hilt for decades now by everyone and their great aunt... i just thought it would be a cool addition to my interior and conversation piece at car shows... i had a special gaugeplates.com plate made up to mount it along with the radio and hvac controls and 2 gauges
can you offer any insight into the wiring and what i should look out for with the neutral safety switch? can i just strip and solder a splice onto the white wire with pink stripe?
In your opening post, you noted you didnt know of any one ever having done it. I just wanted to let you know it had been done, as have RF transmitters and the like.
You can wire it any number of ways. I would use an accessory source for the switch's input. Tap into the interlock circuit before the CSS if you want to have to push the clutch pedal (that's a good idea, not only for safety but for accidental bumps of the button) or wire it after the switch if you don't want to have to push the pedal. Your call.
Always test wires you're going to tap into with a DMM (or test light in this case).
i have a push button in my 89 lx, all i did was replace the cigarette lighter and used the power source from that and ran a wire from the starter relay to the other conector on the button, took me like 10 mins for all of this. i picked the cigarette lighter spot only because i like the hidden part.
HISSIN50 has given you some very wise advice on making sure you do not bypass
the safety interlocks on the starter circuit. Be sure you do as he has recommended.
Typical start circuit...
Starter solenoid wiring for 86-91 Mustang
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
Reactions: Gary Severson
"Tap into the interlock circuit before the CSS" how will i recognize the clutch safety switch (?)
i can't apologize enough for how little i know about automotive wiring, i don't have much experience in this area... would it be too much trouble for you guys to break it down into layman's terms and guide me as to what wire and where to tap into it? will it involve taking my dash apart? is it the white/pink wire at the ignition switch or the red/blue at the solenoid? forgive my ignorance here, and thanks for your time
edit: by the way i have a 3G alt and a mini starter
If you have limited experience with electricty, maybe you should consider another project or recruit someone good with electrical stuff to help.
Here's an online course that you can use to get you up to speed in the electrical department...
Try Automotive Online Instruction for a beginning course. The course is very good and best of all, it is FREE!!!
i like to tackle projects outside my comfort zone, it's the best way to learn! thanks for the link to that course, i'll do my research and ask my father (master electrician) about the wiring diagram... it makes sense to tap into the wire after the CSS to keep that safety precaution functional... if i only knew what the CSS looked like...
edit: good old google answered my question!
You'd tap into the circuit before the CSS (between the ignition switch and the CSS) to keep that functional in your new starting circuit.
As Jrichker noted, if feasible I'd just let your Dad do the install while you watch him. This will make sure it's done proficiently and you'll learn a lot more (watching and listening to him while he works). You will want to solder this connection (the new leg into the white/pink wire) if possible.
Also grab a repair manual. It will help with finding info on things like the clutch safety switch.
Don't take offense. We're just throwing out ideas to try and minimize any issues you might have with this project and down the line.
Good luck.
While browsing my collection of tech notes, I found this one. It uses the safety lockouts to prevent the car from being started while in gear.
Tools needed:
#3 Phillips screwdriver
Small jeweler’s screwdriver
Heat source to shrink the heat shrink tubing.
Soldering gun
Rosin core electrical solder.
Parts needed:
AutoZone Ford electrical connector pin kit
Push button starter switch
18 gauge stranded automotive wire
3/16” heat shrink tubing 6” or longer
1/4 “ heat shrink tubing 6” or longer
3/8” heat shrink tubing 6” or longer
2 each 18 gauge ring terminals
12 each small tie wraps
attachment.php
Make sure the ignition switch is off when you do this. I recommend that you disconnect the ground cable from the battery if you don’t mind losing your radio and computer settings. The computer will relearn the settings after about 15-20 minutes of highway driving.
Remove the plastic cover from around the steering wheel: it is secured in place with 3 Philips head screws.
Remove the ignition connector from the ignition switch. From the front side, use a jeweler’s screwdriver to lift up the plastic finger that holds the white/pink wire in place. Pull the wire out from the rear. Crimp the mating pin from the AutoZone Ford electrical connector pin kit onto the 18 gauge pigtail. What you are doing is adding an extension onto the white/pink wire, so you use a male pin to plug into the female pin that was in the ignition switch connector. Doing it this way will allow a neat and easy way to return to the stock configuration. Put a 1 1/2” long section of heat shrink tubing on the pigtail and then join the connectors. Slide the heat shrink tubing over the exposed contacts and heat until the tubing is uniformly shrunk all around. This will insulate the contact pins and keep the pins from pulling apart. This is one of the wires that will go to your pushbutton, so give some thought to how long you want it to be.
From the front side, use a jeweler’s screwdriver to lift up the plastic finger that holds the red/ lt green wire in place. Pull the wire out from the rear. Scrape a 1” section of the insulation off the wire. Strip 1” off the 18 gauge wire you are using to connect to the push button switch. Wrap in around the bare place on the red/lt green wire and solder it. Cut another 1 1/2” piece of heat shrink and slide it over the bare solder joint. Apply heat until the tubing is uniformly shrunk all around. Slide the red/lt green wire back into the plastic connector shell and make sure it locks in place. This wire provides power to the computer, fuel pump and ignition, so you don’t want it to come loose from the connector shell. Route the two wires down the steering column so that they do not snag anything and tie wrap them in place. Replace the plastic ignition switch cover
Find a suitable place for your push button switch and drill the mounting hole. Crimp a ring terminal on the end of each one of the pigtail wires you ran from the ignition switch. Cut a 1” piece of the 3/”8 heat shrink tubing and slide it on each of the pigtails. Connect the pigtails to the screw terminals on the push button switch, then slide the heat shrink tubing over the exposed screws. Apply heat until the tubing is uniformly shrunk all around. This will protect the wiring from short circuits since the power side of the push button is hot anytime the ignition switch is in the Run position.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information
Ignition switch wiring
Fuel pump, alternator, ignition & A/C wiring
Computer, actuator & sensor wiring
Fuse panel layout
Vacuum routing
Reactions: notch351w
Thank you for the help and patience Hissin50 and jrichter. I haven't taken any offense at all, I appreciate any advice and guidance you guys have given me. I'll take my time and do this right and post pics of the results when I'm finished. Thanks again!
Chris
But don't you still have to put the key in the ignition anyway? Seems a little redundant?
Now if there was a way to install a keyless pushbutton setup that would be sweet as hell! I have that on my G35 and it's nice to never have to take a key out of your pocket to unlock the doors, open trunk or start the car!
I am glad it is redundant. I wouldn't want my car to start unless I had a key or other type of security device.
You are correct about having a "keyless system", it would be nice. Most of us are too busy doing the fixup & power up things to give much thought to that.
Maybe I need to think about one of the thumbprint/fingerprint scanners used with high security computer login. Combine that with the pushbutton start/run and you would really have something.
