Sorry, I was typing with one hand =\ and school's been out for a while.
Thanks.
So the final wiring, Sorry it might be kinda confusing, its in ez wiring terms.
I was able to find a 9v battery and a multimeter, I knew that the yellow one was supposed to go to the battery, so i connected to it, turned the key to the cranking position and found that both of the other wires were receiving current so i connected (ign sw start) the purple one to that. the single wire that received power with the on position i connected (Ign Sw Ign), the brown and the pink, (ign switch coi)l. And for the accessory wire the orange I found out that the back of the ignition has a bolt coming out in which when the key is in the accessory position it gives current to, So, I connected the orange to the back. Is that wiring correct?
