With all of these idle threads that seem to come up more often than in the past I think the reason is cause more peeps are going past typical bolt ons with their combos.
That means airflow during idle has gone up and so much so that the pcm has more trouble maintaining a stable idle.
A few things to think about................
The screw on the tb is not an idle set screw.
It is a stop for the tb blade to prevent it from sticking.
The idle is set in the pcm. That is not to say you can't play with mechanical things and get an idle rpm that is higher but when you do ... it is only because of the pcm's ability to be flexable.
That flexability of the pcm is what I find so interesting. Its ability to adjust for various things (drivability) can be so different for combos that are similar.
As for the isc, it along with the amount of air that is passed at closed throttle through the tb is a balance act kind of deal. If you pass too much air past the tb blade the isc is gonna freak and it goes the other way as well.
Never forget that the pcm expects these things:
1) an idle speed of 650 rpm IIRC (I'm at work at this time)
2) a defined value of airflow at that 650 rpm
3) a defined value of airflow at various rpms like 500, 650, 850, 1200, 2000
We go and put hot rod parts on our cars and items 1,2, & 3 are now way inaccurate and what can happen is that flexability in the pcm we talked about above, may or may not be able to stabilize the idle.
My thoughts for trying to find a stable idle on a h/c/i combo WITHOUT access to the pcm are these in this order ......................
1) Make sure your isc, tps, etc are ok and in good working order
2) Make sure you don't have any v leaks, bad electrical connections
3) Do a pcm reset
4) Make the adjustments to the tb blade stop screw and isc screw as instructed in the threads that have been given
5) Drive around for a few days without making ANY adjustments. This will give the pcm enough time for its flexability strategy to do its thing and allow you to see how much help your gonna get from it.
If you feel a need to adjust things a bit more don't forget to reset the pcm again.
Last thought is this .................................
The pcm can only do so much when we do things that cause it to not understand what is goin on and if those things are too radical... it freaks, lol.
Grady
