I'm Lazy And Tired
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
I'm sure this has been answered but not feeling the urge to search on this. Perhaps you chaps can answer. About 90% on this.
Acquired a set of used Autometer electric water temp and oil pressure gauges. Came with the sending units but here's the rub.
Water sending unit came with the 1/8 NPT- pretty sure the stock size for the sending unit is 3/8 npt so I need to get a 1/8 to 3/8 NPT adapter? I'll relocate the stock sending unit to the thermostat housing.
I'd like to keep the stock oil pressure gauge working with a T fitting. Autometer sending unit thread is smaller then the stock oil sending unit piece coming out of the block that the stock sending unit screws into. Is the stock 1/8 or 1/4 npt. Anyone have a part #.
in case anyone else needs it
water temp is 3/8 NPT and needed a 1/8 to 3/8
Oil pressure sendinng extension is 1/4 npt and needed a 1/4 tee with a 1/4 to 1/8 npt reducer for the autometer sending unit
yep know that thanks- putting the stock one in the rear of the manifold... found this nifty little T fitting for the oil pressure sendor 1/4male x 1/4 female x 1/8 female NPT fitting for $12 bucks
VIAIR T-Fitting 92846
