  • SN95 4.6L Mustang Tech
im new here a ?
  • Thread starter Thread starter 03redstanggt
  • Start date Start date Mar 13, 2007
03redstanggt
  • Mar 13, 2007
im new here with a ?
i have an 03 gt with 30,000 miles on it. i picked up the car 3 weeks ago and sometimes mainly when the car is cold but some times when its warm i head a small tick whick sounds kinda lave a fuel injector tick coming from which sounds like under the car near the exhaust manifolds. can any one tell me if this is anything to worry about or is this normal? i will try to get under there tomorrow or this weekend depending on the weather to pinpoint it. any help will be appricated. .
03redstanggt
  • Mar 13, 2007
one other problem i notice is that sometimes it is hard to shift into second when the car is cold. could it be a clutch adjustment? thank you
04YELLOWGT
1,135
Indiana
Mar 13, 2007
  • Mar 13, 2007
Exhaust leak?
As for the hard shift. I dont know.
CobraRed_96_GT
1,421
UCSD/La Jolla
Mar 13, 2007
  • Mar 13, 2007
your car an auto? sounds like a broken/stuck 1-2 accumulator spring
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Mar 13, 2007
  • Mar 13, 2007
Sounds like an exhaust leak to me. Take it to a shop you can trust. Don't just start replacing things at random.
blubullett
535
Modesto, CA
Mar 14, 2007
  • Mar 14, 2007
The tr3650 transmissions in these cars have an issue with the syncronizers or something. Ford had a warrenty fix that you might be able to get if your still under warrenty. Search tr3650 in the thread search. There might be something in there that will help you.
03redstanggt
  • Mar 14, 2007
well i got under the car today and it sounds like the noise is coming from the passanger header / cat area so im thinking a leak or something and i also noticed that there is more pressure coming out the driver side tail pipe. it was almost 60 degrees out here today and i didnt really have any problems with the tranny. and my car is a 5 speed. and since my car has the factory for warranty on it for another month i went to my local ford dealer to get it checked out.
Mustang5L5
Mod Dude
Feb 18, 2001
43,332
18,059
224
Massachusetts
Mar 14, 2007
  • Mar 14, 2007
The 3650 has a design flaw that causes a clunky/notchy shift into 2nd when cold.
There is a fix for it, but guys have had mixed results with it
Rickey_Bobby
332
Sarasota, FL
Mar 14, 2007
  • Mar 14, 2007
welcome to owning a mustang. You will be plagued by little sounds, bumps, clicks, and squeeks until the day you sell her.
Fix-all for the above:
Turn radio up
put windows down
install a SLP cat back
That will solve most of your problems that would otherwise drive you nuts but never really warrant the time and $$ to fix them.
good luck
sgarlic
3,085
Mar 16, 2007
#10
  • Mar 16, 2007
  • #10
As said above, there's a technical service bulletin out for that 1-2 clunk sound. The first remedy is to try changing the fluid fill level in there to whatever it recommends. Next step would be to get the parts the TSB says and replace the syncros.
The exhaust leak is an easy fix. Check the tightness of the bolts where the header bolts to the midpipe. If it's loose, tighten it. Check for cracks.. if there are, weld them up.
Exhaust ticking isn't a normal sound, not even on Mustangs... except maybe for some people who take no pride in the mechanical condition of their car or something.
03redstanggt
#11
  • Mar 16, 2007
  • #11
well im bringing the car to ford on monday since it is still under warrenty. thanks again for your help
N
Sticky Throttle
  • NooStang
  • Jun 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
General karthief
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
  • Gulftown980x
  • Jul 29, 2026
squeak93
