well its been a stressfull week. ive had no car because ive been putting on my sc. i get it on and it wont run. 2 days go by and i get it to run. go down to the dyno tuner and 2 hours a custom chip and $700 later im making 404ft/lbs of torque at the wheels at 4500rpm (cant rev any higher cause its too lean). he tells me i need a new maf (80mm pro-m) and 42# injectors plus an t-rex inline pump in addition to the 255lph pump i already have. i say ok, no big deal. i had to borrow the money from my mom cause im broke right now. so i owe her $700. now for the bad part. aparently when i put the car back together i cut the power wire to the radiator fan and didnt know it......oh ****. ran hot going to the tuner and on the way home but not that bad. get off the freeway and it gets bad. rushing to my g/f house so i could shut it down i blow a mother ph**king head gasket wow, that $2700 in the last week went real far <-----im being sarcastic if you couldnt tell. anyways, long story short, im broke and have a blown head gasket and pray i didnt bend a valve. white smoke pured from my car everywhere filling the street when it happened. the oil pan is full of coolant. pulled the dipstick and the fluid level was about 4-5" above the "full" line. coolant blew out my coolant overflow tank and went all over my msd box. i was able to drive it about a half block cause thats how far i was from her house when it happened. do you think i could have driven it if i had a bent valve? after it happened i thought i just smoked the tires or something but then when it began to sputter i got scared. anyways, i need a set of gaskets. i was thinking all metal like copper or aluminum (not sure which it is). what do you guys think? what thickness is stock? if you have a summit link that would be amazing cause i have to order these NOW!!!!! i dont want this to ever happen again so i want good ones.
im so ****ing stressed you have no idea
