im screwed!! help me!
  • Thread starter Thread starter luckythirteen13
  • Start date Start date Sep 20, 2005
First Prev 2 of 2
ljinx23
163
Northeast Pennsylvania
Sep 21, 2005
#21
  • Sep 21, 2005
  • #21
that #4 cylinder doesn't sound too promising.
old_blue
1,783
282
124
Sep 21, 2005
#22
  • Sep 21, 2005
  • #22
sounds good man. Doesn't seem to be as much a problem as you originally thought. Good luck man.
Dbeck002
710
South florida
Sep 21, 2005
#23
  • Sep 21, 2005
  • #23
Everyone is right, there is an underlying problem here. I'm pretty sure since you told me the A/F was super lean at the higher RPMs, that you should get a set of 42 lbs injectors. I know they are expensive but is tearing down your engine everytime those 24s run lean, worth it? The 255 pump is fine IMO, but definately get 42s man, and the PRO-M while youre at it.
I am 99% sure that once you get the 42 lb injectors youll never run lean even if you tried.
L
luckythirteen13
648
Anaheim, CA
Sep 21, 2005
#24
  • Sep 21, 2005
  • #24
ya my dyno tuner told me to stay off the gas till i got 42# injectors and a 80mm pro-m but im looking at a 75mm pro-m with injectors on ebay so im hoping that will be enough. my tb is only 70mm but we will see, maybe ill hold out for the 80mm. he also told me that the 255lph in tank pump needs the help of the t-rex to feed the engine. ill have to put the inline pump in after i get the engine running again. i think at 4700 the engine was at 15.5:1 so its definetly a fuel related issue
First Prev 2 of 2
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
