Everyone is right, there is an underlying problem here. I'm pretty sure since you told me the A/F was super lean at the higher RPMs, that you should get a set of 42 lbs injectors. I know they are expensive but is tearing down your engine everytime those 24s run lean, worth it? The 255 pump is fine IMO, but definately get 42s man, and the PRO-M while youre at it.
I am 99% sure that once you get the 42 lb injectors youll never run lean even if you tried.
