Immaculate Vortech Supercharged Rio Red 95 Cobra
bottlefed88
101
Holland, MI
1995 Rio Red, Tan Leather Cobra with 96,000 miles
West Michigan
I bought this car from a buddy of mine and have done an extensive list of very tasteful mods and restoration items to it recently. This car is truly one of the cleanest SN-95’s I’ve come across; impeccably clean for a MI car. I’m the third owner, my buddy bought it from an older gentleman with 25,000 miles in 1999. My buddy stored it every winter and took immaculate care of it – you could eat of the underside of it – zero rust! I’d like to pursue building a new project for the NMRA so gauging interest in the Cobra. This car drives so beautifully and could easily be daily driven in its current state. You will not be disappointed; I’ll let the pictures speak for themselves. Working on more pictures so please forgive me.
MODIFICATIONS – All parts are new with less than 1000 miles
Engine and Cooling:
New Vortech V2 @ 10 lbs, T-REX, 10:1 FMU, and BTM
New NGK TR6’s @ .035
New MSD Cap and Rotor, Summit 8mm Plug Wires
New MSD Blaster TFI Coil
New PowerMaster 200 Amp Alternator (done right - new 4 gauge wire, 200 amp fuse, and 4 gauge ground)
New Stewart High Flow Water Pump and high flow 180 degree thermostat
New Ford Racing Harmonic Balancer
New Front Main, Water Pump, and Timing Cover gaskets (bead blasted cover and thermostat housing)
New Fluidyne 3 Row Radiator with $$BeCool Coolant and Redline Water Wetter (doesn’t get over 185)
New Good Year Blue Hi-Miler Hoses
New CSR Polished Billet Aluminum Catch Can and Matching Bracket
BBK Longtube 1 5/8” Headers
BBK Offroad H-Pipe
Flowmaster 2 Chamber 40 Series, Dumped
Driveline:
New Spec Stage 2+ Clutch (smoothest operating clutch setup ever – everything is new)
New Ford Racing Pilot Bearing, Clutch Fork, Flywheel, Steel Retainer
New Centerforce Throwout Bearing (the good one – no chirps)
New Maximum Motorsports OEM Clutch Cable
New UPR Click Firewall Adjuster and Quick Release Clutch Quadrant
New Fel-Pro Teflon Rear Main Seal $$ Best one you can get (zero leaks)
New Ford Racing Aluminum Driveshaft
New Ford Racing 3.73’s
New Ford Racing HD Differential Cover
New Ford Racing Speed-Cal
New Ford Pinion Seal
New Lakewood Pivot Ball Stud
New B & M Ripper shifter
New Royal Purple Syncromax Fluid – T5 Shifts Like Butter
New Royal Purple Gear Max Rear End Fluid
Suspension, Brakes, Tires:
New BFG KDW G-Force tires 255/40’s
New PowerSlot Rotors Front and Rear
New Hawk HPS Pads Front and Rear
New Replacement Shocks, Sway bar
Interior:
New Killer System ($2k+) – 2 Rockford 10’s, Infinity Amp, Capacitor, Alpine deck
New LRS Floormats
New Autometer Boost and Wideband 02 – Tuned very safe high 10:1 low 11:1, 19 degrees total timing
New Ford Ignition Cylinder
Exterior:
New LRS Replacement Cobra Headlights and Markers
New Bosch Wipers
New Replacement Door Locks and Trunk Lock – all new with new key fob and keys
New Painted Mirrors, Rocker Panels, Driver’s Door, Driver’s Rear Quarter Panel, and Rear Bumper. Professional Buff on all remaining body – This Car Looks New!
80 Percent of the exterior paint is original and extremely mint – hard to believe this is 17 year old paint. I had some dings taken care of because I’m so anal. The only non original paint is on the driver’s rear quarter, door, rear bumper, mirrors, and rocker panel plastic. If it wasn’t perfect, I had it redone. Everything else is Ford OEM. The match is absolutely phenomenal.
Like I said, just gauging interest so I can fund a new project. This car is the perfect driver, should run high 11’s on drag radials at 113-115 mph or so. Stone cold reliable, perfect compression on all cylinders, zero oil leaks and does not burn a drop of oil. It truly is the perfect foundation for any drag or autocross/road race project.
$11k obo, I have that into it in the last month.
Thanks,
Matt
269-369-9042
[email protected]
