  • SVT Tech Forum
Imrc options
  • Thread starter Thread starter 93blown50
  • Start date Start date Jan 17, 2011
9
93blown50
15
  • Jan 17, 2011
Hi I have a 1998 cobra that has a imrc actuator problem from what I am gathering there is not a replacement available this seems crazy to me does anyone know of any options here for me I thought about delete plates but I don't know much about them Like what they will do to my gas mileage and drivability any input will be appreciated.
Steve491
254
Charlotte, NC
Jan 29, 2011
  • Jan 29, 2011
If you're sure it's an actuator problem and you can't find one then you have no choice but to eliminate the actuator. You can either install delete plates or half-ass it and wire the existing open. I have a 97 and one of the cables popped off the rod in the IMRC plate. It didn't throw any codes but it ran like poop. I would be certain that it was bad before eliminating the IMRC system because even though it's a poorly designed electro-mechanical system,.... It does work when it works. Gas mileage is another story. It's a Cobra, not a prius. I doubt mileage would be affected much, but I could be wrong. Low end (under about 4 grand) will suffer. Just me 2 cents.
Steve
9
93blown50
15
  • Jan 30, 2011
Well I found a actuator and installed it they are both working correctly now but I have another problem in first and second gear the car looses power around six thousand but in third gear it runs to seven thousand and seems to have no problem.
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
96 Cobra IMRC delete, dyno’d
  • Gunmonkey
  • Aug 29, 2024
  • SVT Tech Forum
SVT Tech Forum Nov 7, 2024
Gunmonkey
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
C
Fox Need help identifying brake setup
  • Cypher02xd
  • Apr 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
Mustang5L5
  • SVT Tech Forum
