In--stall--lation--help--
  • Thread starter Thread starter seedog
  • Start date Start date May 7, 2005
seedog
  • May 7, 2005
Hey Guys, I Just Redone My 351 Cleveland And Am Putting It Back In With Set Of Long Tube Hedders.the Motor Hooks To A Top Loader. Is There A Easy Way Get The Thing In??????? I Would Appreciate Any Advise. Thanks Seedog//////////////////////////////////////////////////////
rbohm
6,698
550
204
tucson,az
May 8, 2005
  • May 8, 2005
set the headers in the car and hold them inplace with coat hangers. as you lower the motor in the chassis, move the headers around so the engine slides into place. as for the tranny, get a pair of long bolts, about 6" will do just fine, cut off the bolt head and cut a slot in the freshly cut end. run these bolts in place on the top bolt holes for the trans. slide the trans on the bolts, leaving the trans in a gear(any gear will do) slide the trans forward and turn the output shaft untill the input shaft splines line up with the splines in the clutch disc, then just slide the trans home. you may have to move the tail shaft up or down a bit to get the nose of the input shaft to slide into the pilot bushing. take your time and DONT force anything.
W
top loader transmissions
  • WilliamJCC.
  • Jun 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 6, 2026
70mstang
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
